Use this procedure to configure the maximum EAP and NEAP MAC clients supported on a port.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Set the maximum limit of allowed EAP and NEAP MAC clients supported on the port:
    eapol multihost mac-max <1-8192>
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface GigabitEthernet 1/16
Switch:1(config-if)# eapol multihost mac-max <1-8192>
The following table defines parameters for the eapol multihost mac-max command.
Variable
Value
mac-max <1-8192>
Specifies the maximum number of EAP and NEAP MAC addresses allowed on the port. The maximum limit is 8192 MAC addresses.
